Arc Fault Breaker Required in Garage?
Regarding occupied garages and AFCI's.
Observation suggests building permits with plans & inspections for room additions is a desire of law, but perhaps not always defacto.
If unpaid contractors are willing to purchase a ~$100. city business license, they can report permit violations to local code enforcement, and leverage adopted Uniform Building Codes 18.90.110 (.030) to fine or revoke occupancy, before filing mechanics liens.
However, contractors attempting to leverage code enforcement on the cheep are referred to a peace officer, who must issues fines for operating without a local business license. Minor services less likely to report permit violations, are even less likely to purchase business licenses.
Building permits have been arranged to occur between occupancy, and HUD inspectors that don't need permits can still miss locked garages. Further, licensed contractors with access to government leverage may be avoided by sub-cultures originating from corrupt governments. Avoiding local tax increases tied to total area of occupancy, also avoids revocation of occupancy with building hazards.
People who allow contractors in their garages may agree to remove extension-cord wiring, add GFCI's, dual function for laundry, or drive missing ground rods for sub-panels, but are perhaps less likely to pull permits and invite inspectors to an existing garage not planned for occupancy.
While removing acute fire & safety hazards won't void insurance policy, and may reduce the chance of casualty, the law can't force insurance to cover claims where a required AHJ inspection was avoided. Especially if that occupancy is still missing required insulation, gas-appliance ventalation, egress lighting, or smoke/CO detectors. Therefore, it would seem the building records render most homeowner claims void after such remodels & additions.
The local AHJ combo inspectors that emerged after the recession of 2008 are not electrical-code wonks, not expected to ID counterfeit equipment listings, much less master residential, commercial, and industrial Plumbing / HVAC / Electrical / Energy / or Framing standards forced on their plate.
Combo inspectors need help from the qualified electrical contractor to recognize wiring methods not listed for the purpose, or box fill & receptacle-spacing codes, much less the difference between a GFCI, and dual function AFCI / GFCI for garage occupancy. Combo inspectors may not even recognize NFPA-70, unless directed thru their State-adopted publications. 2017 NFPA-70 406.4(D) should be referenced as: 2019 California Code of Regulations (CCR) Title-24, Chapter 3, Section 406.4(D).
A switch is an outlet if it's a dimmer, or if it's lighted. If that switch uses any electricity, it's an outlet.
There simply is no "period" about it
Lighted, maybe.
Dimmer, no. Dimmer has losses by nature but it's primary function isn't to produce heat, it is a control device.
A combination inspector pointed out, when discussing the limit of receptacle replacement code 406.4(D) and AFCI's, NEC 210.50(A) defines pendants as receptacle outlets.
Who would imagine replacing a fexible cord pendant defined by 314.25(C), must include AFCI protection for swag kits for ceiling fans & such.
It seems you're wavering back and forth between what constitutes an outlet in a general sense versus an outlet as it pertains to an afci circuit.
We're talking past each other I think
My comments are only based on the Article 100 definitions. The type of circuit does not have anything to do with the question of a switch being an outlet.
A switch is not and has never been an outlet for the application of any NEC rule.
It's required to wire switches with a neutral for a reason. Dimmer switches use electricity
A control device that uses power for its operation is still not an outlet. The control device is just that, a control device. The fact that it uses power does not make it "utilization equipment". Outlets are the point on the circuit where the power leaves the branch circuit and is connected to the " utilization equipment ".
