it's pretty bad when you start quoting yourself, but it's come to that.
i did a little more research on the ideal 61-165 suretest... it is a pretty
slick device. there is no way to hide from it, either.
here's why i popped for it.... it'll find false grounds within 15' upstream
of a device, without taking the circuit down. i've got a building to clear
the neutral faults from. this is going to make that a whole lot easier.
it'll also do real time voltage drop at 12, 15, and 20 amps
it'll measure bolted fault current available at that point.
don't even ask me how that works. maybe zog knows.
it'll measure impedance on all three wires, telling you which one
is funky.
it'll test gfci's and tell you how many milliseconds and how many milliamps
it tripped at.
so, i stick it in the ... plug, and it tells me:
