dotman
New member
- North Dakota
According to the latest NEC what are the circuits requiring arc fault breakers and installation guidelines?
Yes this means any place that electrical current can be connected to electrical equipment for use. this would mean that all lights, smoke detectors, receptacles, and or room air conditioners that use 120 volts.current is taken to supply utilization equipment
Don... supply 125-volt, single-phase, 15- and 20-ampere outlets ...
It should be changed to say:All branch circuits that supply 125-volt, single-phase, 15- and 20-ampere outlets installed in dwelling unit bedrooms shall be protected by an arc-fault circuit interrupter listed to provide protection of the entire branch circuit.
The Canadian Electrical Code does not permit smoke alarms to be connected to AFCI or GFCI protected circuits.Here in Champiagn Illinois, the city has ammended the code as to not wanting smoke detectors on the afci circuit. Anyone eles doing this?
why not tell us who you are?(BPH, I have never seen you post your name, calling you BPH seems impersonal)
