Why does a GFCI trip immediately if you touch load side neutral to ground even when there is no load connected at the time?
Basic concept of GFCI operations should not trip until there is current but they will trip every time you touch unloaded neutral to ground.
Seem to be having difficulty finding information on this, probably just using wrong key words in the search, but did find this:
They call it neutral to ground fault detection but it would also allow it to detect a fault on the "phase conductor" to another same "phase conductor" in about the same manner.
