Bompa
- Bremerton, WA
Arc Fault Lower Limit?
This question concerns whether there is a practical lower limit below which the energy available makes Arc Flash Labeling unnecessary.
I know there is an exclusion for ?dwelling units?, but does every other piece of electrical equipment that possibly would be checked while energized require labeling? If it does, does it follow that a person opening the case of such a labeled piece of equipment need to have the certified training, the safety suit, etc. that has come to be associated with the ?Arc Flash Hazard? warning label?
Surely, there must be a point below which the labeling is not required. If not, we are going to see such labels on everything and the real meaning will be lost. Neither the code language nor the NEC Handbook seem to address this.
