Arc fault problems
dave blethen
glen spey ny
electrical contractor
Has anyone had a problem with the arc fault breakers after a solar system was installed we wired the house 2 years ago now all the arc faults keep tripping. I was told to put in arc gfi combo breakers this will solve the problem. This doesn’t make sense to me but. I tried it and for 2 days no trips anyone know why.
Newer versions seem to be sorting the bugs out better. There were a lot of them.
The home owner resets the breakers it random breakers tripping not always the same this all started when the solar system was installed a few weeks ago i have replaced every breaker twice the last time is with arc and gfi comdos just found out yesterday that the tripping just started again the home owner noticed it happens when the solar system goes from sun to batteries
AFCIs will trip when power comes on, when power is lost, because of transients, harmonics, any number of things.
I commonly have GFCIs trip when utility power is lost, and they need to be reset. AFCIs are worse.
It seems that you have narrowed it down to the power switching over, so it’s more than likely some irregularity in the inverter.
Other than that, I have no useful advice, except pull all the AFCIs out and throw them in the trash. They’re just snake oil anyway.
I guess you could put a power logger on it and see what is actually happening and see if an SPD or some type of filter would work.
Personally I’d just toss the AFCIs. 😂
