618electrician
- St. Louis
- Maintenance electrician
arc fault receptacles vs arc fault breakers. when and ware 2020 nec?????????????????????????????????????????????????????????????????????????????????????????????
All of you posts have a million question marks. I know there is a minimum character requirement but try to use other letters, numbers, symbolsv so you questions don't look so demanding.arc fault receptacles vs arc fault breakers. when and ware 2020 nec?????????????????????????????????????????????????????????????????????????????????????????????
The way i read 210.19 A 2020 nec the only time i can use a AFCI RECEPTACLE is to extend a extend a existing non AFCI circuit over 6 feet .New construction vs remodel might make a difference.
