Ok, I have a few questions... First, I put in a new CH AFCI today, this feeds a new room addition, wired in #12, 20A breaker. It leaves the panel and goes to the first of 4 outlets, leave the outlet and goes to a switch and overhead light. From one of the outlets I put a 12/2 up to a smoke, from that smoke 12" away (on the other side of the wall) I put a 12/3. The circuit holds fine, the minute you plug a smoke in it trips the AFCI. Keep in mind this is dedicated, the wire all exposed, new and in great shape and the AFCI holds just fine until you put a smoke in. The AFCI holds with all sorts of plugged in equipment, lamps, etc. We changed the AFCI, put in 2 different brands of smokes... All the obvious. This one has me scratching the old head...
OK, #2 - I was talking to an inspector and he said that the 2005 edition of the code sunsets on Jan 1, 2008 in regards to AFCI protection. He says since the code "sunsets" on this date and no manufacturers make the new AFCI's that they will no longer be required - by code - but they will still enforce the 2005... Hmmmmm. I believe I read this in the Forums as well, anyone have any additional thoght on this?
As always, Thanks in advance -
