kwired
Electron manager
- NE Nebraska
- EC
For 2011 that is correct. For 2014 they possibly could save some print space by telling us where AFCI is not required in dwellings, there is not many places left that don't require it. Primarily outdoors, garages, unfinished basements, crawl spaces are about it, most everything else now requires AFCI if it is 15 or 20 amp and 120 volts.What Code are you following? In NYC we are under 2008 but I thought even in 2011 I didn't think you needed AFCIs in kitchens (where the micro, fridge, etc. would be).
Add: if you have a switch for an outlet in one of those spaces I mentioned above in a space that otherwise requires AFCI - you still need AFCI so one common example is outdoor lighting wouldn't require AFCI, but if the switch is inside - it likely still requires AFCI because of switch location.
