lielec11
- Charlotte, NC
- Electrical Engineer (PE)
If, based on an arc flash risk assessment performed via the incident energy analysis method (aka SKM, ETAP, EasyPower, etc.) the incident energy is considered "dangerous", or over 40cal/cm2, does that mean under no circumstances you can operate that device? So if you have a $60,000 circuit breaker you're not allowed to open or close it because the arc flash hazard is greater than 40cal/cm2?
