Yes, you must always use the appropriate PPE. Per NFPA70E, I can find no reason you should be working on a lighting ballast "hot".Are you required to wear proctive gear if working on a 277v ballest if it's hot?
it`s only 277 but it can kill
Are you required to wear proctive gear if working on a 277v ballest if it's hot? What class would this be??
