I believe I have enough to proceed . I do have 2 more items I'm not sure about , does the 120 volt washer outlet require ground and arc fault ?
Yes -- Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
210.12 Arc-Fault Circuit-Interrupter Protection
(A) Dwelling Units. All 120-volt, single-phase, 15- and 20-ampe re branch circuits supplying outlets or devices installed in dwelling unit kitchens, family rooms, dining rooms, living rooms, parlors, libraries, dens, bedrooms, sunrooms, recreation rooms, closets, hallways, laundry areas, or similar rooms or areas shall be protected by any of the means described in 210.12(A) (1) through (6):
210.8 Ground-Fault Circuit-Interrupter Protection for Personnel
(D) Kitchen Dishwasher Branch Circuit. GFCI protection shall be provided for outlets that supply dishwashers installed in dwelling unit locations.
Does the circuit to an unfinished basement require arc fault ? It has lights and a single GFCI receptacle . The reason for all the questions is my code books are 2006 and I'm building my own house . Is it a similar area? may be your inspectors call -- Probanly yes due to the additions of closets,hallways & laundryrooms
