arch from water meter jumper
It could be that you have lost the service neutral. Check the neutral at the
panel & the meter. Call POCO to check their neutral at the pole or dog house.
Do the neighbors have any problems ? That would be arc. Leave the water ground connected until you resolve this problem.
The water pipe is in parallel with the neutral(s). Be it just an earth connection or neighbors bond to a community water line. Some current flow is normal and to be expected. Clamp a meter around your water line and or jumper just to see how much you have. The current may be in house or the neighbors problem. Be careful, under the right conditions this could be deadly.
