Shujinko
I have an existing installation with a clear NEC violation of the tap rule 240.21(B)(3). An existing switchboard feeds a transformer which is over 25' away. The primary feeder connects directly to the Switchboard Distribution bus without any over current protection. There isn't any over current protection on the primary or secondary side of the transformer to protect the conductors. Where the XFMR primary feeder connects to Switchboard bus there looks to be corrosion, however I wanted to get this forum's opinion if this is only corrosion or if some arcing burn marks are present as well? Looks like just corrosion but I am not an expert either. See pic below. I need to make the owner aware of the code violation but wanted to see whether to include any mention of corrosion and/or arcing on the Switchboard Distribution Bus.
