JFletcher
- Williamsburg, VA
My mistake, I was thinking of the top half of the split bus
No-Ark Model #116-68C.
The left side breakers are, from top to bottom, labeled a conventional 1, 3, 5, 7, 9, 11, 13, and 15. The right side however goes 2, 4, 6, 8, 10, 12, 17, 14, 16, 18. Breakers #17 and #18 (which are both 1p with a 2p breaker between them) have no amperage markings and each feeds a lug in the top half of the panel.
To secure all power, the 2 2p breakers and 2 1p breakers in the bottom half of the panel (where the feed lugs are) must be turned off. If one was just securing the top half, then both 1p breakers #17 and #18 would have to be secured.
Here's what the panel looks like:
eta: I've seen older CH tri-split panels that have 6 2p breakers in the top 1/3rd of the panel (no main); all 6 must be shut off to pull a meter.
