FionaZuppa
- AZ
- Part Time Electrician (semi retired, old) - EE retired.
a friend of mine does all sorts of stuff for halloween and had some bulb flashers made from FS2 starters (a common way to make a bulb flicker). this one was a small 15w incandescent bulb. oddly it would trip gfi recept every so often. so i went over to take a look and i could not find anything wrong in terns of ground faults anywhere, and this flasher was the only added item to the ckt via extension cord. the flasher itself is housed in a 1/2" pull box and is two wire only.
so why would a gfi recept trip on a hot-to-hot arc (thats what the FS2 is doing).
