Are boxes reguired for all surface mounted light fixtures? Where in the NEC code is this stated?
B Barkerkb New member Oct 31, 2010 #1 Are boxes reguired for all surface mounted light fixtures? Where in the NEC code is this stated?
Buck Parrish Senior Member Location NC & IN Oct 31, 2010 #2 No, Flourescent lights do not require boxes. Thier may be others.
jumper Senior Member Location 3 Hr 2 Min from Winged Horses Oct 31, 2010 #3 Barkerkb said: Are boxes reguired for all surface mounted light fixtures? Where in the NEC code is this stated? Click to expand... If you are talking about a surface mounted flourescent or similar, than no. 300.15(B) (B) Equipment. An integral junction box or wiring compartment as part of approved equipment shall be permitted in lieu of a box. For most others,yes.
