Bob Anchorite
Are Electrical Utility companies like dept. of water and power... etc., are they required to follow the NEC codes in their installations and work?
Bob
Bob
Your local or state utility commision regulates and monitors the POCO.Bob Anchorite said:That they can do whatever they please no matter what the results... is there any oversight agency?
What is it they did that your upset aboutBob Anchorite said:That they can do whatever they please no matter what the results... is there any oversight agency?
they are required to be insured so they have responsibility. you just have to prove they are at fault. thats the hard partBob Anchorite said:Just got the feeling that they could care less. But I have no actual ax to grind. A friend of mine lost about 5 grand of equipment in his home due to an arc condition where the service conductor finally melted at the pole. Now the poco says they don't have to be responsible. Wondering if they have any responsibilities to the safety of the community.
Jim on Collier parkway is a golf community you know the one that took out the last orange grove in that area.Well in the next to last phase there was a home that had a xfmr set and by the time they graded it the xfmr was almost 4 ft above grade due to survey problems.Then the rains came hurricane season Katrina etc.In 2 weeks the xfmr was in the bottom of a 4 ft washed out area.All underground services.Exposed laterals!!!!It took almost 5 months for them to come and correct the problem.Jim W in Tampa said:What is it they did that your upset about
