I need to install a field barrier inside of a class 1 division 1 area. The barrier is installed inside a class 1 division 1 box. The rigid conduit running from the non-safe area shall have a seal off less then 18 inches before it enters the box. All points that leave the box will be intrinsically safe. Do I need seal-offs for all other points that leave the box and enter the class 1 division 1 area? Can I use a cable gland? The wire is instrument tray cable (shielded).
