zemingduan
- Philadelphia,PA
- Electrical Designer
These are line voltage 125A apartment feeders running from the apartment distribution panel to each electrical panel inside the apartment unit. The whole run is probably 100'+. This is a portion of the run!How long is the run? Are these line voltage or low voltage cables?
Ask 100 people and more people would say that they're bundled than those who said they're not bundled but ultimately it's the inspector's call. Given the small air gaps around each cable it's not likely that there will be an issue with overheating.As Trevor stated there is no clear definition of bundling. For instance, how much space is required between cables to not be bundled? The case of bundling may be an authority having jurisdiction call. In this case I would probably consider it bundling but as you see there are places where the cables do have space between them.
I doubt the calculated load is a 100 amps, if it was called out for bundling change the feeder breaker to a smaller size. I wouldn't call it bundling just don't add zip ties between strapping thinking you want it to look neaterDo you see any issue with the installation in the below picture? Are the cables correctly supported only by one bracket? I think the space may not maintained between the cables. Derate of the conductors need to be considered?
Not so easy to do. If there are 10 cables you would have to de-rate to 50%I doubt the calculated load is a 100 amps, if it was called out for bundling change the feeder breaker to a smaller size. I wouldn't call it bundling just don't add zip ties between strapping thinking you want it to look neater
True you could separate them into a couple of groups without doing each one individuallyNot so easy to do. If there are 10 cables you would have to de-rate to 50%
The ampacity adjustment rule does not use the word "bundled". It requires that you "maintain spacing" between the cables to avoid a requirement for ampacity adjustment. To me that is saying if you want to avoid the ampacity adjustment, you have to do something to maintain the spacing.Bundling is not defined by the NEC so if the inspector thinks that it's okay it's good enough for me.
That’s vague also. How much is proper spacing? 1/8” - 1/2” - 1’. They should have a bare minimum.The ampacity adjustment rule does not use the word "bundled". It requires that you "maintain spacing" between the cables to avoid a requirement for ampacity adjustment. To me that is saying if you want to avoid the ampacity adjustment, you have to do something to maintain the spacing.
But isn't everyone leaving out the "..... Without maintaining space for a continuous length greater than 24 in" part? In other words, all you have to do is stick some spacers in there every two feetAs Trevor stated there is no clear definition of bundling. For instance, how much space is required between cables to not be bundled? The case of bundling may be an authority having jurisdiction call. In this case I would probably consider it bundling but as you see there are places where the cables do have space between them.
There was a proposal for one cable or wire diameter a couple of cycles ago but it failed.That’s vague also. How much is proper spacing? 1/8” - 1/2” - 1’. They should have a bare minimum.
Nice. Always best to keep it vague and undefined so everybody will be unsure what to do and wondering if they'll pass their inspection.There was a proposal for one cable or wire diameter a couple of cycles ago but it failed.
Not touching.That’s vague also. How much is proper spacing? 1/8” - 1/2” - 1’. They should have a bare minimum.
