ptonsparky
Tom
- EC - retired
We have a single painting that needs lighting. Any suggestions as to lamp particulars. LED spot is my guess but any CRI or temp suggestions?
These are the best bulbs I can find for lighting artwork.We have a single painting that needs lighting. Any suggestions as to lamp particulars. LED spot is my guess but any CRI or temp suggestions?
https://www.soraa.com
Make sure you test the bulb, transformer, and dimmer at your shop before you go out to the field. The bulb/transformer has been known to hum with Lutron dimmers.
Look for a bulb with a high R9 ratings.
https://www.soraa.com/learn/science/why-understanding-r9-not-just-cri-matters-you
Sent from my Pixel 2 XL using Tapatalk
LED's work by generating UV to excite phosphors coating the interior of the "bulb". Does anyone know what UV leakage there might be with these products? You definitely do not want to be spraying UV all over your Jackson Pollock.
For some reason I thought LEDs were low in UV. IDK, now.
