There needs to be dedicated space clearance above a panelboard per 110.26.
A plumber wants to run a gas line above a circuit breaker enclosure that has two circuit breakers in the enclosure.
Is a circuit breaker enclosure with 2 circuit breakers in it considered a panelboard?
If there was 1 breaker in the enclosure, I wouldn't consider that a panelboard, but what if there's two breakers in the enclosure?
