Eddie702
Licensed Electrician
- Western Massachusetts
- Electrician
Basically for a dwelling unit(s) only the Code has decided over many years of calculations and load reports from dwelling units that regardless of the size of the service installed the conductors are almost never loaded to more that 83% of the service size.........just something somebody dreamed up I guess. So for a dwelling the over current protection must be 100 amps minimum size and the code making panels have decided that a wire rated at least 83% of the over current rating is in a dwelling only suitable for the service or a feeder that carries the entire load.
