jclint07
- south missouri
Here is my dilemma. Our local power company requires the grounding electrode conductor to be terminated in their metering equipment, effectively grounding their neutral. They have required that for years. As the new AHJ electrical inspector, I informed them that the electrode conductor needed to be landed in the service equipment main disconnect instead (NEC 2008 Art. 250.24(A1). They are fine with that as long as the electrician installs a grounding electrode "jumper", from the grounding electrode conductor at the main disconnect, out to there meter base and bonds the effectively grounds their neutral. Wouldn't doing so be a violation?
