ce1mattapoisett
New member
I am running romex in a one story commercial Steel building with 4 small offices wood framed
and stapling on the bottom of the joists running across the joists I am doing this above a drop ceiling. Is this ok or does it violate 334-12A which states cable shall not be used as open run in dropped or suspended ceilings in other than one or two family dwellings.
