article 334.15b
southernboys
hey guys hate to bring this back up. my question is does this article refer only to second and third story buildings or does it cover floors in a slab? if so why cant I use pvc pipe as a chase pipe to pull nm cable to my kitchen island? also if this article does not refer to slabs doesnt my pvc pipe act as a moisture barrier?
Re: article 334.15b
I'll second that. From the handbook commentary on the definition of location - wet:
It is intended that the inside of a raceway in a wet location or a raceway installed under ground be considered a wet location. Therefore, any conductors contained therein would be required to be suitable for wet location.
