2008 code change states that the use of USE cable is not permitted to used as "an interior wiring method" In a recent 15 hour code update ,the teacher stated that "tri/plex, underground service cable , is not permitted to enter a foundation, into a panel even if in conduit with a LB because this was considered an interior wiring method. Has anyone else run into this issue???
