408.4 Field Identification Required.(A) Circuit Directory or Circuit Identification. Everycircuit and circuit modification shall be legibly identified asto its clear, evident, and specific purpose or use. The identificationshall include an approved degree of detail thatallows each circuit to be distinguished from all others.Spare positions that contain unused overcurrent devices orswitches shall be described accordingly. The identificationshall be included in a circuit directory that is located on theface or inside of the panel door in the case of a panelboardand at each switch or circuit breaker in a switchboard orswitchgear. No circuit shall be described in a manner thatdepends on transient conditions of occupancy.
(B) Source of Supply. All switchboards, switchgear, andpanelboards supplied by a feeder(s) in other than one- ortwo-family dwellings shall be marked to indicate each deviceor equipment where the power originates.
