dnbob
- Rochester, MN
I have read many posts as well as article 645 (NEC2011)
I am unclear when article 645 applies, and when it doesn't, based on previous posts
I am trying to understand the rules for a data center for a local utility company. I can't think of any wiring that would not be a chapter 3 wiring method. I assume with some help on definitions, that this would resolve the answer as to whether the disconnecting means would be required per 645.10. The drawings I have seen show this, but only disconnect the CRAC units, not any other power.
Thanks,
Bob
Thanks,
Bob
