I recently went on a service call to a fish farm. They have a building with tanks that are in-ground. Each of the in-ground tanks have (2) 3 phase, 480 volt aerators that are fed with (4) wire SOW (3 hots & 1 ground). The aerators are hardwired to a PVC box in the ceiling. Each aerator has its own single pole triple throw non-fused disconnect switch that hangs from the ceiling over the walkways that separate the in-ground tanks. None of the circuits are currently GFCI protected. I started looking in the 2011 NEC in article 682 to see if I could determine if these needed to be GFCI protected, but the only items mentioned in 682.15 are ?15 and 20 amp single-phase, 125-volt through 250-volt receptacles??..? I can?t determine if the switches, which by default would make the aerators need to be GFCI protected. Any thoughts?
