ARTICLE 780 Closed-Loop and Programmed Power Distributio
charlie
Indianapolis
Panel 10 has accepted a proposal to delete ARTICLE 780 Closed-Loop and Programmed Power Distribution, does anyone know of anyone that is using this article? :confused:
Re: ARTICLE 780 Closed-Loop and Programmed Power Distributio
Hi Charlie:
If I understand the scope of this article, it would apply to some home energy management systems that use a signal over power lines.
Is that your interpretation as well ? Some of these systems are still in use as far as I know.
Oh...alright.
Hey wait...remember me and Jim outvoted you 2-1 on the meeting you weren't invited to. (you tend to get more free beer that way, I have found). Or did you and Jim outvote me in SC when I wasn't there? :D
The manufacturer, Smarthomes LLC, went bankrupt. I read in the handbook that the article was left in the NEC as there are still homes wired with it.
It would be a first to have an article deleted, the NEC would get somewhat smaller!
I forgot to add Art 780 is where NM-S cable is used. We often don't see the NM-C and NM-s in Art 334.
I've never seen NM-C but its similar to UF.
The way I remember it, you were outvoted in absentia. :D
