jsharvey
- Mayetta Ks
I work for a company the manufactures railroad signal huts. The way I read 90-2, the wiring we do at the plant that will connect to the commercial power, ie. lighting, outlets etc, when the hut is located is subject to NEC. But the signalling equipment installed by the rail road is not. Am i reading this article correctly and if not could someone please explain? I am the only licensed electrician working for the company and whenever I point out a problem I keep getting the " rail roads aren't subject to the code" answer.
Thanks
Jim
Thanks
Jim
