Where does it say you can pass through air handling space but run parallel in air space? I know I read and I think there is even a picture but I can find it. Thank gus
Are you allow to use nonmetallic cable ( NM ) in these space as well. Can I use NM to pass through the joist space?
Dennis, Wouldn't the above restriction not apply to the space noted in the exception ?300.22(C)(1)
In other words, cables in the exception would not have to comply with (C)(1() therefore NM would be allowed.
