charlie there is nothing on the prints, they just want the house wired to code.
back before the housing bust i had this 'resi questionnaire' i'd send those sorts>>>
COMPREHENSIVE MASTER LIST
Service Kitchen Devicing & Trim
100amp UG/OH____ counter lenth(s)___ normal ivory or white__
150amp UG/OH_____ penensula________ decora___________
200amp UG/OH____ island___________ dimmers # of_____
simple meter________ trash comp______ fan controls______
meter/main________ dish___________ automation______
temp service_______ disposal________ plastic iv or wh plates___
power co_________ micro___________ Low Voltage
WR #____________ vent hood________ # thermostat runs_____
pole #____ ft away___ electric range______ # phone runs_________
Panel fixed refer_________ # cable coax runs_____
# circuits_______ other fixed appliances___cable or dish server___
m.l.o._________ Garage Y____N___ interface location_____
w/main________ attached_________ CAT5PAR4 & RJ6____
location________ detached_________ #Speaker runs_______
metal H20______ distance_________ Structered system________
grid ties________ door opener(s)____ Bathroom(s) #1, #2, #3 #4...
# subpanels____ subpanel____________ fans________
# outbuildings___ power required________ fan/lights____
Furnace Basement fan/light/heat___
# circ's_______ full______ fan/light/heat/NL___
#zones_______ partial___ shower recessed___
#z-valves______ crawl____ other needs_______
type controller_____ Construction Size
Hot H20_____ normal stick built______ sq feet_____
Air cond_______ stress skin___________ # of bedrooms____
hvac__________ log__________________
Special needs Generator Interface Y___N___ Other
chime kit___ whole house________________ Well pump____
alt power interface- dedicated subpanel__________ Septic pump____
surge supp TVSS_ dedicated circuitry___________ Electric Dryer____
dedicated ph lines__ # of dedicated circ's__________
low-v lighting_______ maunual transfere____________
burgler alarm_______ automated transfere__________
dialer system_______ KVA_______________________
central vac_________
whole house fan__
line v smokes_______
hvac_______________
~RJ~
