Thabiso
- South Africa, Cape Town
A three phase motor is installed to drive a single conveyor belt forward and backwards on a car assembly line. The circuit specifications are as follows:
Supply line voltage = 400V
Frequency = 50Hz
Power rating of motor = 8kW
Power factor = 0.8
Length of cables = 100m
Hint: quote all cables used.
Questions:
Yours Sincerely
Thabiso:roll:
Frequency = 50Hz
Power factor = 0.8
Questions:
- Choose a suitable cable and give reasons
- Select a suitable method of installing the cable and give reasons
- Make a labelled sketch of the control circuit of the diagram and the power diagram.
- Name the type of conduit used to connect the motor to its control panel and give reasons
- Calculate the minimum cable size for the installation
- Calculate the actual voltage drop of the installation
- Calculate the percent voltage drop
Yours Sincerely
Thabiso:roll:
