kwired
Electron manager
- NE Nebraska
- EC
my reply in that thread is consistent with what I have said in this thread:180528-2026 EDT
kwired:
At
http://forums.mikeholt.com/showthread.php?t=174880&highlight=amperage+inrush
is a thread I started on motor inrush current being non-existent, but rather there is a starting current that is larger than normal running current. The plots I showed had no observable inrush current.
Inrush current dominantly lasts only about 1/2 to 1 cycle, and is usually very large compared to steady state current. Motor starting current typically lasts for a large number of cycles, and is not as huge relative running current.
If you remember you responded in said thread.
I know that there are many that want to call motor starting current inrush current, but motor starting current is so different in its character from other initial currents that it confuses peoples understanding of what is happening in a circuit when the term inrush current is substituted for motor starting current.
If you don't understand how different components and circuits work, then you are not in a good position to design circuits or troubleshoot problems.
I will concede that "motor starting current" is likely the more correct term to use. I will also say that in casual conversation with most field electricians, it really doesn't matter to be that precise, either way many realize there is an initial surge of current that is quite a bit higher then normal operating current and that overcurrent protection must be able to ride through this surge of current without opening the circuit.All he is saying is that the transient current that happens when starting a motor is not quite the same as the transient current that happens when energizing a transformer.
To most field electricians, there is still a transient current that occurs when energizing either one and they seldom need to know much more then that.
There are many that think this starting current and locked rotor current are the same level of current - which is not true.
