sparkysparks9
- Coos Bay OR
I am Retrofitting a 80kw generator into an existing building. The question i have is with the grounding.
The way the system is set up now...3phase 4 wire
utility to CT can, from CT can parallel runs to a 300 amp panel, then another 250 amp dist panel is fed from CT can as well.
Do i need to change the grounding and bring it all to the ATS, as it now seems to be the first disconnect? Neutral in not switched in this ATS
