ATS as main disconnecting means
explorer22002 said:
Is a motorized circuit breaker type automatic transfer switch allowed to be used as the main disconnecting means?
We use service rated ATS's all the time. You can manually disco the service if needed.
But to be precise, your transfer switch MUST be labeled for that use, i.e. a S.U.S.E. label. But most of the ones that use breakers are labeled that way, that's the advantage of using them.
