The following is my situation: the secondary from the utility run approximately 300 feet to the electrical service in the building 277/480 3P 4 Wire ? the client wants to install an ATS adjacent to the Utility transformer in that the generator is also located in the utility yard. If I install a 4 pole switch (Isolating the Neutral) will this resolve the problem with bonding the neutral conductor to the building ground at the ATS? If not, any suggestions other than attempting to pull equipment grounds in the existing conduits.
