Re: Attic acess clearence?
Originally posted by macmikeman:
I think the last several replies to my drilling the truss is full of beans and I am going to tell you why. Generally an access hole to an attic is located in the hallway. You have a bearing wall on either side of the hallway.
Walls under the truss you are drilling do not make a difference.
The fact that you think it does make a difference tells me you do not understand how a truss works.
The bottom chord of a truss keeps the ends of the truss from spreading, much like collar ties in a conventional roof system.
This can be a very important feature for those of us in the snow belt, add 6", 12", 20" of snow on your roof and you do not want any weak spots.
Something for someone in your location does not have to worry about I think.
I started wiring houses in 1976 and have not caused a single one yet to fall down.
It is important to remember that just because you have always done something that way does not make it correct.
I do not think that
any of us think drilling a few holes would cause a collapse, but the fact is these are engineered products and in many areas of the country building inspectors will not allow any modifications (including holes for wires) without documentation from an engineer or the truss manufacturer.
The rafters are quite fine from my seldomly drilled puka (hole in Hawaiian).
You do understand there is a large difference between rafters and trusses right?
There are quite a few of the responders to posts on this site who I am not sure if they actually know anything about what they are actually posting about.
Well that is interesting, as at least a few of these guys responding to your post on drilling holes in trusses are inspectors and have attended training is building codes.
As for my self, I am not an inspector but I have worked on enough jobs to know that you never drill engineered lumber products with out express permission.
Now, it is 38F here this morning how do I get a job in Hawaii?
[ October 03, 2003, 05:52 AM: Message edited by: iwire ]
