cadpoint
- Durham, NC
I'm not following - There's 48" between what and what?![]()
S:
S:
IE where the wire is laying, measuring straight up is 48", is the way I read it.
I should have clarified - I meant to say: so what?
Okay that changes things but all these threads you have started not any of them had me freaking out worrying. I have seen 100 times worse all over the place.
this previous thread has interesting discussion oin this point:
334.23 In Accessible Attics.
http://forums.mikeholt.com/showthread.php?t=90528&highlight=320.23
Code is code is code.
What gives any inspector the right to decide what to, and what not to enforce?
If there are permanent stairs to this attic, it is quite plain in 320.23
Pierre, what about the "opinion" that the framing members that are present in most of today's houses are either "ceiling joists" or "trusses" and not "floor joists" as the wording in 320.23 states.
Are pull down type stairs considered permanent? They are anything but "stable".
I've been wondering the same thing.
Jeff,
Before you start adding more pictures, could you answer my question? What are you taking issue with in the original (edit) fourth post?
No, I goofed. I guess I'm getting totally being heavily filtered when I mistake an 8 for a 4.wrong post # reference????
Or does this finially show that I'm totally being heavily filtered.............
