I cant draw a diagram. But consider this. Most serious audiophile have individual circuits to equipment. Usually 4. 1 for amps. 1 for preamps. 1 for digital gear and the final for infrastructure related to digital such as LPS feeding modem, router, switch.
Lets look at the amp and preamp. Phase A is 121 volts to my amps. The amps are feed by a dedicated Hot, Neut and ground. The preamp is feed by Phase A. Its 120 volts hot, neutral, ground. A difference of 1 volt. Not much of anything to standard residential or commercial equipment. But remember, we are dealing with equipment that has a transform that weighs about 1 OZ and puts out milivolts or power. That power is boosted to around 900 volts. Then bucked back to around 2 to 8 volts. Now, that amp circuit and preamp circuit acting independent would not have any issues. But I go and attache a wire between the 2 pieces of equipment that is tied to the signal. I now have one piece of equipment at reference Hot to Neutral of 120 volts and the other at 121 volts hot to neutral tied together. Now there is 1 volt of potential in the circuit. And what can that volt do when your manipulating the entire signal and power voltage to such extremes. That very small voltage potential can make all sorts of heard noise out the speakers.
Because of this very issue, there is hot debate over 1 circuit for everything, or multiple circuits. 1 circuit means everything is at the exact same potential. Unless of course you are using esoteric power cords of different lengths, geometry, gauge etc. The way the cord is built will impact the inductance and capacitance through the cord which will also affect voltage at the gear. Gear that has a signal wire tied together. Many people advocate a loom of wire from one source for this reason.
I always advocate using multiple circuits because I feel the parasitic noise from each piece of gear needs some conductor between them to reduce its impact. And I will put certain devices such as servers and DAC on a filtering power strip to keep that noise from feeding back into my amps and preamps.
Audio is way more complicated than people want to admit.
