K8MHZ
- Electrician
Thankfully, I haven't had to deal with many issues on cars. And on that newer farm machinery with up to 1 1/2" thick harnesses, if a harness goes bad we usually just replace it.
Yes, without wiring diagrams you can end up going in circles.
Trailer wiring is usually pretty a standard color coding. I've learned the hard way that white is usually negative or "ground".
There is almost a standard for trailers!
Here is what I use. Note that nothing is mentioned about the trailer brakes needing a larger wire?
