Autotransformer w/ GFCI to pool pump
The supply is 240v single phase..... there is a DC inverter inside the pump, and then it converts to 3-phase AC to power the VFD.
The pump in question is a Pentair IntellifloXF. http://www.pentairpool.com/products/pumps-inground-intellifloxf-variable-speed-pump-452.htm
Because the supply is 20A 240v single phase, I believe the GFCI rule still applies.
My bad, I think. I kept thinking of the "Pentair" cabinet pictured in your OP and was thinking it was the VFD and the motor was remote from it.
Got the transformers in and everything seems to be working normally......
Finished product....
And the pool of course ...... these guys do awesome work.
Do you have the make/model of the tranformers you used and any other config detail? I'm in the same boat now
This OP is from several years ago. Please start a new thread if you would like to continue the discussion.
