Bugman1400
- Charlotte, NC
Bugman, Mivey...
"The Y-D-Y will act as a zero sequence source for whichever wye-side is grounded (or both sides if they both are grounded). The buried delta can circulate zero sequence currents from either side."
"Zero sequence currents will not pass through if either or both sides are ungrounded."
The first is correct, but the second... !
Phil
I see nothing wrong with the second statement but, as always, you need to make sure your interpretation of the meaning is the same. I interpret the second statement to mean that zero seq currents cannot pass from the primary to the secondary side of a YDY xfmr where either Y side is ungrounded.
