JELECT.
New User
- New York State
- Elactrician
What are the grounding, bonding, and grounding electrode NEC requirements, regarding the use of a portable generator used for back-up power to a residential home? this generator would be plugged into a 30 amp 125/250 volt 4 wire male inlet which connects to the main panelboard through a manually operated 30 amp, 2-pole circuit breaker that can only be closed by opening the main 100 amp service breaker which is mechanically interlocked with 30 amp breaker?
