One's enough, don't do it.Originally posted by domnick:
Backfeeding into dryer circuit with portable generator, how many no no's
Originally posted by tshea:
Whenever we get a call we tell them straight up, the generator has to be isolated from the poco lines.
Of course its dangerous - no question there.Originally posted by wyatt:
... at best $200-300 to do it right. ...
I'm impressed. That's pretty good. This is a good example of why I'm not in the electrical installation business. I'd starve to death.Originally posted by wyatt:
Carl, we set a sub panel ch makes a breaker defies that goes between to breakers that only allows on breaker to be on at one time. ... the cost is a low end, all manual ... more for new home not to add one. parts around $150
Domnick -Originally posted by domnick:
after 27 hurricanes this year I started buying sq`s model of what CH makes same principal but alot cheaper.Like $75.00 with 4/8 circuits.Originally posted by wyatt:
Carl, we set a sub panel ch makes a breaker defies that goes between to breakers that only allows on breaker to be on at one time. put the feed on one braker and the gen on the other. put in the sub panel what you want on the gen. the cost is a low end, all manual,portable gen type 30 amp. more for new home not to add one. parts around $150
Thank you for your suggestion. I likely would never have thought of that.Originally posted by charlie b:
... So I might suggest you find a copy of the NEC Handbook. I don't own one myself ...
