G
		Guest
Guest
Before a workplace injury I was a service electrician and a small electrical contractor (licensed). Because of my experience I will NEVER ever backstab another switch or receptacle! Most of my service work was done in the mid-90's. Most of the dwellings were built in the early 70's. This meant the devices (receptacles & switches) were about 25-years old. They were all "BACKSTABBED". They were all arcing to some degree. Some arced to the point of circuit or device failure. They never tripped the circuit breakers. Many had little white hot fires burning within the devices. I am now a SIDEWIRING fool! Everything I do is box made-up, pigtailed and sidewired! Due to my injury I am out of the trades, but I am going to re-enter it as a hands-off contractor. I will be the brains and I will hire the necessary brainy/brawny electricians to do the physical work for me. I feel that BACKSTABBING should be ILLEGAL! It does not work over time. The little flat spring that keeps the wire in place and makes the electrical contact: Think about it: Only about 2-molecules of metal on the spring contact the round conductor. With on & off cycles, heat cycles, etc. the connection starts to arc. It is a ridiculous system! It is dangerous! It needs to be banned!
I bought a Broan heat/vent/light/night-light for my own bathroom last week. I was ASTONISHED that the 4-device toggle switch for this unit REQUIRES that the 1500 watt heater be BACKSTABBED! There is no way to side-wire the heater switch! There are only pigtails for the light and night-light on the switch unit. The pigtails are only rated at 3-amps! The rest is all backstabbed! Yuk!
How long do you think it will take for backstabbed devices to start tripping the AFCI breakers?
How do you feel about backstabbing?
Do you box make-up your neutrals and grounds, or do you rely on backstabbing and using the device as a wire nut? You know that's wrong but I would like to hear about your methods.
I know many of you box make-up and pigtail your grounds and neutrals, but in the field I had to undo a lot of shoddy work. I would add any form backstabbing to the list of shoddy work. It may be NEC approved, but that could only be through strong lobbying by Leviton, etc. It does not hold up!
I hope this AFCI breaker works out. It is a fabulous concept. It's going to be hard to troubleshoot the faults, and there will be a learning curve, but AFCI is the future.
Sorry for the long post. I look forward to your comments about AFCI, backstabbing, and box made-up neutrals/grounds and pigtails. :roll:
