- Massachusetts
Units designed for portable use in OSHA environments are likely to have the entire output GFCI protected to reduce the need to GFCI individual circuits.
OSHA does not require GFCI protection on 240 volt 30 amp circuits either.
But I do agree with you and why I asked what use the generator is designed for.
The real answer here maybe that homeowner should consider getting the right kind of generator for supplying a premises wiring system.
