Can't see the video.
mobile
Had to View In Browser. Another Tapatalk limitation. Sigh.Security settings maybe?
I can see it on desktop and Droid.
Sure sounds like either a loose bus section or a problem with the mag trip in the breaker.
I suppose it could be wire movement in raceway too.
mobile
That almost sounds like a transferred vibration noise.
Like the agitator of the washer when it moves in steps or moves back and forth.
As loud as that is (or seems to be) I would think it would be easy to find.
If it was a constant buzz or vibration I would point at electrical but that isn't what its doing.
It doesn't happen every time the washer or dryer is running. FYI, the washer & dryer are on the main level. This panel is located in the basement area.
The washer when agitating is a varying load, each time it changes direction the load decreases then increases again. Any magnetic caused humming from the breaker will increase and decrease as the load changes.That almost sounds like a transferred vibration noise.
... because I cant get the pictures to zoom ...
... I couldnt see the pictures well enough either.
